chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
cmassey
Apr 09, 2012Guide
cduce wrote: Any guidance on this will be appreciated :)
Did you see the post above?
cmassey wrote:
So I decided to upgrade to 4.2.20 [T32] installed what I needed and moved back to 4.2.19 (not sure if this was a good or bad thing to do but no issues so far for the NAS or Virtualbox)
