chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
indomiti
Apr 28, 2012Aspirant
I tried to follow j6harri guide but i think something goes wrong with my VirtualBox kernel modules?
RAIDiator 4.2.20 and VirtualBox 4.1.14
# VBoxHeadless -startvm "Debian" &
[1] 12927
Netgear-NAS:/c/VirtualBox# WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.37.6.RNx86_64.2.2) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
# /etc/init.d/vboxdrv setup
Recompiling VirtualBox kernel modules ...done.
Starting VirtualBox kernel modules ...failed!
(modprobe vboxdrv failed. Please use 'dmesg' to find out why)
# modprobe vboxdrv
FATAL: Error inserting vboxdrv (/lib/modules/2.6.37.6.RNx86_64.2.2/misc/vboxdrv.ko): Invalid argument
