chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Xaver
Apr 28, 2012Tutor
is it save to upgrade from 4.2.17 to 4.2.20 with VBox Installed or should i first deinstall the Vbox and so on before Update.
does the 4.2.20 now support the reinstall of the Vbox system?
