chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
InTheShires
Apr 28, 2012Tutor
cmassey wrote:
Was working fine until I upgrade to T20, it stopped working after the upgrade tos so I reinstalled, and still not working.
Will keep playing and may roll back firmware to see if that fixes the issue.
4.2.17 was all I could make it work happily with. I tried the final of 4.2.19, and a couple of 4.2.20 Txx betas, but never got it running happily. I've resisted the urge to try 4.2.20 Final so far... :|
