chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
indomiti
Apr 29, 2012Aspirant
Ok, i start from beginning, kinda..
So i do make CONFIG_DEBUG_SECTION_MISMATCH=y
Could this be the cause of the problem?
# cd /c/VirtualBox
# apt-get update
# apt-get install build-essential amd64-libs lib64stdc++6 bzip2 lib64z1 lzma
# apt-get --reinstall install libc6-amd64
# apt-get -f install
# rm -rf linux-2.6.37.6
# unzip -q RNDP6xxx_4.2.20_WW_src.zip "linux-2.6.37.6/*"
# ln -snf `pwd`/linux-2.6.37.6 /usr/src/linux
# cd linux-2.6.37.6
# cp arch/x86/configs/defconfig.smp .config
# make ARCH=x86_64 silentoldconfig
# make prepare
# make modules_prepare
# make, this warning comes at the end:
WARNING: modpost: Found 1 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
# make CONFIG_DEBUG_SECTION_MISMATCH=y, this warning comes at the end:
WARNING: drivers/target/target_core_mod.o(.text+0x5cf5): Section mismatch in reference from the function init_module() to the function .init.text:rd_module_init()
The function init_module() references
the function __init rd_module_init().
This is often because init_module lacks a __init
annotation or the annotation of rd_module_init is wrong.
