chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
gexxie
May 04, 2012Aspirant
Same problem here
:/vm# sudo /usr/bin/VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-4.0.2-69518.vbox-extpack
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.37.6.RNx86_64.2.2) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
You will not be able to start VMs until this problem is fixed.
0%...
Progress state: NS_ERROR_FAILURE
VBoxManage: error: Failed to install "/c/vm/Oracle_VM_VirtualBox_Extension_Pack-4.0.2-69518.vbox-extpack": Extension pack 'Oracle VM VirtualBox Extension Pack'is already installed. In case of a reinstallation, please uninstall it first
NAS:/vm# sudo /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel modules ...done.
Uninstalling old VirtualBox DKMS kernel modules ...done.
Trying to register the VirtualBox kernel modules using DKMS ...failed!
(Failed, trying without DKMS)
Recompiling VirtualBox kernel modules ...failed!
(Look at /var/log/vbox-install.log to find out what went wrong)
