chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
JeIlMa
Jun 11, 2012Aspirant
Hi
I really need help with reinstall virtualbox to ReadyNas Pro. I manage to get it work in 4.2.17 but now I have trying to remove it and make it work in 4.2.20. So I probably mess up my current installation.
First problem is error below (from apt-get update). I assume that it is something that I don't have to care (annoying but harmless). I'd like to fix it however...
W: GPG error: http://www.readynas.com 4.2.20/ Release: The following signatures were invalid: BADSIG B7F02108D553259A RAIDiator Release Key <[email protected]>
W: You may want to run apt-get update to correct these problems
When I try to go thru section 2 I will get this error...
WARNING: modpost: Found 1 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
It comes in both make and make modules.
If I just ignore these and try "./VirtualBox-4.1.14-77440-Linux_amd64.run"
netgear:/c/Virtualbox# ./VirtualBox-4.1.14-77440-Linux_amd64.run
Verifying archive integrity... All good.
Uncompressing VirtualBox for Linux installation...........
VirtualBox Version 4.1.14 r77440 (2012-04-12T16:28:20Z) installer
Please install the build and header files for your current Linux kernel.
The current kernel version is 2.6.37.6.RNx86_64.2.2
Problems were found which would prevent VirtualBox from installing.
Please correct these problems and try again.
It is ok to remove all virtualbox settings (I don't have any old virtualbox running) but I need to sure need some instruction to do it.
-JeIlMa
-JeIlMa
