chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
cmassey
Jun 24, 2012Guide
I never got it working, but i tried again with the 4.2.21 and got futher than I did with 4.2.20.
Give it some more time and I suspect I will get 4.2.21 working it just finding the right tweaks and settings to get it right.
The biggest difference between the 2 is this command didn't work (unzip -q RNDP6xxx_4.2.20_WW_src.zip "linux-2.6.37.6/*")
It appears to now be stored into a sub folder of the kernel directory, also arch/x86/configs/defconfig.smp didn't exist (or should I say I didn't find it so I used the one from 4.2.20)
Anyway I will keep playing with it or hope that someone with more skills than me is kind enough to type up a how to guide :)
