chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
j6harri
Aug 09, 2012Aspirant
@MattyShack
Thanks for getting me past that problem. I was able to complete the rest of your guide except for 1 option section of installing webmin. Do you have any ideas for this error.
NASHOG:/c/addons-config/VirtualBox/backup# dpkg --install webmin_1.590_all.deb
(Reading database ... 24830 files and directories currently installed.)
Unpacking webmin (from webmin_1.590_all.deb) ...
dpkg: error processing webmin_1.590_all.deb (--install):
unable to create `./usr/share/webmin/custom/help/before.de.html': No space left on device
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Errors were encountered while processing:
NASHOG:/c/addons-config/VirtualBox/backup# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 4185780 2446680 1529388 62% /
tmpfs 16 0 16 0% /USB
/dev/c/c 9699971712 4693302100 5006669612 49% /c
/c/backup 9699971712 4693302100 5006669612 49% /home/ftp/backup
/c/media 9699971712 4693302100 5006669612 49% /home/ftp/media
/dev/sdh1 1945752432 318645440 1627106992 17% /USB/BackupNAS
