chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
MattyShack
Aug 09, 2012Tutor
If I understand this line: "unable to create `./usr/share/webmin/custom/help/before.de.html': No space left on device"
You are out of space on your "/" main partition. How much free space is reported for "/" when you type: df
If there is a space issue, try clearing out your /tmp directory then run df again to see how much space has been reclaimed. Webmin is not a requirement, so you may need to skip.
