chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
MattyShack
Sep 14, 2012Tutor
As long as your source list is limited to the following:
deb http://www.readynas.com/packages 4.2.21/
deb http://www.readynas.com/packages 4.2.22/
deb http://archive.debian.org/debian etch main
Should be fine because the system will ask you whether or not to accept the recommended changes. Say <N> if you think the selected packages will cause conflicts. If so, go with 'update' instead of 'upgrade'. On my system, I think I had better success using 'upgrade' in that particular sequence. I agree, it's best not to make a habit of using 'upgrade'.
