chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sander11
Oct 03, 2012Aspirant
After looking around at the problems with 4.2.22 I decided to go with 4.2.21. I was able to complete the configuration with Virtualbox 4.2, which appears to be working, but I haven't tested it yet with an actual vm.
Unfortunately the phpadmin isn't compatible with 4.2 (they apparently have a different definition of 'latest' than I do :roll: ) it appears to show the status, but points you to the 4.2 beta when you start.
MattyShack you are amazing!
