chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
InTheShires
Oct 31, 2012Tutor
I'm having trouble getting any joy with this, so I've pulled together some of the messages that I get when attempting an install of VBox and the EXT packs. I get the same failiures whether I'm on the latest 4.2.22 firmware, or downgraded to 4.2.21.
Basically, to my untrained eyes, I'm getting mixed messages as VBox is supposedly installing fine, but then I get this error... "Error! echo
Your kernel headers for kernel 2.6.37.6.RNx86_64.2.4 cannot be found at
/lib/modules/2.6.37.6.RNx86_64.2.4/build or /lib/modules/2.6.37.6.RNx86_64.2.4/source."
Anyway, hopefully the following will shed some light for somebody. With the help of a friend we've concluded that it "could" just be that my system is borked in some way, from my constant tinkering and adding bits and bobs here and there. But I'd sooner not face a total factory reset, if at all possible.
lsmod and modprobe vboxdrv outputs are below somewhere.
Thank you to any of you who took the time to read this post!
OBJCOPY arch/x86/boot/setup.bin
OBJCOPY arch/x86/boot/vmlinux.bin
HOSTCC arch/x86/boot/tools/build
BUILD arch/x86/boot/bzImage
Root device is (9, 0)
Setup is 13804 bytes (padded to 13824 bytes).
System is 3551 kB
CRC cbca6fd1
Kernel: arch/x86/boot/bzImage is ready (#1)
Building modules, stage 2.
MODPOST 4 modules
CC drivers/scsi/scsi_wait_scan.mod.o
LD [M] drivers/scsi/scsi_wait_scan.ko
CC drivers/target/iscsi/iscsi_target_mod.mod.o
LD [M] drivers/target/iscsi/iscsi_target_mod.ko
CC drivers/target/target_core_file.mod.o
LD [M] drivers/target/target_core_file.ko
CC drivers/target/target_core_mod.mod.o
LD [M] drivers/target/target_core_mod.ko
ITS:/c/addons-config/VirtualBox/kernel/2.6.37/linux-2.6.37.6#
ITS:/c/addons-config/VirtualBox/kernel/2.6.37/linux-2.6.37.6# make modules
CHK include/linux/version.h
CHK include/generated/utsrelease.h
CALL scripts/checksyscalls.sh
MODPOST 4 modules
ITS:/c/addons-config/VirtualBox/backup# ./VirtualBox-4.2.2-81494-Linux_amd64.run
Verifying archive integrity... All good.
Uncompressing VirtualBox for Linux installation............
VirtualBox Version 4.2.2 r81494 (2012-10-18T14:46:00Z) installer
Installing VirtualBox to /opt/VirtualBox
Python found: python, installing bindings...
Building the VirtualBox kernel modules
Error! echo
VirtualBox has been installed successfully.
You will find useful information about using VirtualBox in the user manual
/opt/VirtualBox/UserManual.pdf
and in the user FAQ
http://www.virtualbox.org/wiki/User_FAQ
We hope that you enjoy using VirtualBox.
ITS:/c/addons-config/VirtualBox/backup# modprobe vboxdrv
FATAL: Error inserting vboxdrv (/lib/modules/2.6.37.6.RNx86_64.2.4/misc/vboxdrv.ko): Invalid argument
ITS:/c/addons-config/VirtualBox/backup# lsmod
Module Size Used by
iscsi_target_mod 244720 0
target_core_mod 264451 1 iscsi_target_mod
pvgpio 11438 0
nv6vpd 9334 0
ITS:/c/addons-config/VirtualBox/backup# /usr/bin/VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-4.2.2-81494.vbox-extpack
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.37.6.RNx86_64.2.4) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
You will not be able to start VMs until this problem is fixed.
0%...10%...20%...30%...40%...50%...60%...70%...80%...90%...100%
Successfully installed "Oracle VM VirtualBox Extension Pack".
ITS:/usr/src/vboxhost-4.2.2# uname -r
ITS:/usr/src/vboxhost-4.2.2# cp *.ko /lib/modules/2.6.37.6.RNx86_64.2.4/
ITS:/usr/src/vboxhost-4.2.2# sudo /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel modules ...done.
Uninstalling old VirtualBox DKMS kernel modules ...done.
Removing old VirtualBox pci kernel module ...done.
Removing old VirtualBox netadp kernel module ...done.
Removing old VirtualBox netflt kernel module ...done.
Removing old VirtualBox kernel module ...done.
Trying to register the VirtualBox kernel modules using DKMSError! echo
...failed!
(Failed, trying without DKMS)
Recompiling VirtualBox kernel modules ...done.
Starting VirtualBox kernel modules ...failed!
(modprobe vboxdrv failed. Please use 'dmesg' to find out why)
ITS:/usr/src/vboxhost-4.2.2# /etc/init.d/vboxdrv stop
ITS:/usr/src/vboxhost-4.2.2# /etc/init.d/vboxdrv restart
