chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sander11
Nov 10, 2012Aspirant
My eyes are equally untrained. I had problems in some parts of the script where it looks like mattyshack has an alias (or something else) where sometimes the path doesn't include "/c/" before addon-config so I'd look for that.
Are you sure you did the part where it says:
# Copy VBox Modules into the directory matching your kernel release from uname -r
# If you have RAIDiator 4.2.21 installed, it should match 2.6.37.6.RNx86_64.2.4
Code: Select all
uname -r
cp *.ko /lib/modules/2.6.37.6.RNx86_64.2.4/
Code: Select all
uname -r
