chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
InTheShires
Nov 10, 2012Tutor
sander wrote: My eyes are equally untrained. I had problems in some parts of the script where it looks like mattyshack has an alias (or something else) where sometimes the path doesn't include "/c/" before addon-config so I'd look for that.
Are you sure you did the part where it says:
# Copy VBox Modules into the directory matching your kernel release from uname -r
# If you have RAIDiator 4.2.21 installed, it should match 2.6.37.6.RNx86_64.2.4
Code: Select all
uname -r
cp *.ko /lib/modules/2.6.37.6.RNx86_64.2.4/
Thanks for the reply Sander, yes, I have copied the VBox modules over, I think the output is listed above in my post, but I've not checked.
As for the paths being inconsistent, I can't say I really noticed but when I try again, (it's on the backburner again for the next few days) I'll be sure to keep the paths identical each time.
Thanks again. :thumbsup:
