chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
InTheShires
Feb 05, 2013Tutor
Almost there with this now. I HAD to drop back to 4.2.21 because I just could not get the source to behave on 4.2.22. After downgrading to 4.2.21 most seems to be working properly.
I'm still having an issue, which is the reason for my post. I've always manually installed PHPVBoxManager, rather than using the WhoCares addon as this was my previous method which never caused me any problem. However, I'm trying with the latest version of PHPVBoxManager (4.2-4) but it's not working as previously it did under v 4.1-8. I'm getting to the point of using the old v4.1-8 version, but wondered before I go tinkering again, if anyone was having any success with the latest version of PHPVBoxManager?
Thanks
Thanks
