chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sander11
Feb 17, 2013Aspirant
I'm running 4.2-2 but I used Whocares addon as described in the how-to and it works although on my last reboot I had to restart the vobxweb-service to login.
I can share any directories or config files if your interested.
