chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Mar 09, 2013Apprentice
Wow, matty this was quite a procedure. I finally bit the bullet because I really want to run some things I can't on etch. So thanks for the detailed instructions. I got through everything and didn't toast the system :-) so that's the good news. However at the end after the last reboot when I try to open phpvboxmgr on the web I get an error about namespace not found from php. There is another couple of guys who had this using whocare's addon but they could not recall how they fixed it. I'm using whocare's PHP addon. Maybe there is a config step related to that I'm missing?
thanks,
steve
thanks,
steve
