chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Mar 09, 2013Apprentice
Ok, I'm in but it required admin/admin even though I put different strings in config.php. You mentioned the same thing happened to you. When did it switch? I've logged out and in but it still wants admin/admin.
thanks!!
steve
thanks!!
steve
