chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
MattyShack
Mar 09, 2013Tutor
Don't know why, but follow the instructions using VBox manager to add the vbox user, then delete admin. Make sure you give it admin rights.
# The user was 'admin' not 'vbox'. I then used [File] -> [Preferences] -> [Users] to add User 'vbox' as an (Admin User).
# At this point, you should logout and log back in as User 'vbox' and [Delete] User 'admin'.
