chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Mar 10, 2013Apprentice
Ah, regarding httpd.conf, I skipped the php section because I already had it installed, but the links and whatnot to fix up /etc/apache2 were in there. I went back and cleaned that up, but you might want to move those out of the php install or highlight them as steps to take if you already have it. Thanks again!
steve
steve
