chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
MattyShack
Mar 10, 2013Tutor
### VirtualBox is available in a number of package formats native to various common Linux distributions
### Editor: Matty Shack
### Document Version: 2.10 (VirtualBox-4.2.10-84104)
### Date: 21 March 2013
### VBox: 4.2.10
### PURPOSE: Provide instructions to install a functioning VBox on the ReadyNAS x86
# Oracle VirtualBox References:
# Home: http://www.oracle.com/technetwork/server-storage/virtualbox/downloads/index.html
# Latest Version: http://download.virtualbox.org/virtualbox/LATEST.TXT
# User Manual: http://download.virtualbox.org/virtualbox/UserManual.pdf
# SDK Ref: http://download.virtualbox.org/virtualbox/SDKRef.pdf
### WARNING: There may be typos and grammar missteps. I'm no expert or even a programmer,
### but this guide includes many hours of typing, trial, error and hair loss.
### I'm sure there are better ways to express different aspects of this guide and coding,
### so please be kind as you post recommendations for fixes and improvements.
### The lines that start with a ':' indicate that you have already followed this complete guide with success,
### but want to start over and try some new changes. For example, I messed up the permissions and could not
### get anything to work without deleting VBox and starting fresh. So I only needed to follow the ':' lines
### as all other relevant steps like, compiling the kernel, had not changed. Do not type the ': '. It is only
### used as a reference to identify the correct lines to focus on if you are conducting a partial rebuild.
### If the system reports that it cannot write because you are out of space, type 'df' to check disk space and 'df -i' to check for free i-nodes.
### Disk Space: There must be space available on the file system, meaning that there are still unused data blocks.
### i-Node Metadata blocks: Whenever a file is created on a file system, an inode is used to contain information about the file.
### Most file systems have a fixed amount of inodes. The available number of inodes are set during the mkfs operation of the file system.
### The only way to fix either problem is to free space/i-nodes by deleting files in /dev/md0. Start with your /root, /tmp, and /var/log directories.
### As others have voiced, NetGear does not appear to be interested in the ReadyNAS line anymore.
### VBox may extend the life of your server and allow it to be re-purposed beyond its creators' original intent.
### I ask that others on this forum continue to lend a helping hand as they share their knowledge and experiences
### with new users.
### Thanks
### *** My READYNAS Box Setup *** ###
# System: NetGear ReadyNAS Ultra 6, 6x3=18TB, 4GB Memory
# Installed Firmware: 4.2.22 ~ RNDP6xxx_4.2.22
# Linux OS: Debian v4.0 ~ Etch
# CPU Core: Intel dual core x86 (64 bit)
# NOTE: Based on the stock ReadyNAS CPU, it does not support Hardware Virtualization (Hyper-V).
# This means that many advanced OS's like Windows8 or OSX will not run from these servers.
# However, I've upgraded my CPU from E2160 to E7600. I can now run Win8Pro in a VBox VM.
# See thread http://www.readynas.com/forum/viewtopic.php?f=35&t=29284
### *** Target Files: Virtual Box 4.2.10-84104 (This install uses x86_64)*** ###
# VBox Runtime Linux x64: http://download.virtualbox.org/virtualbox/4.2.10/VirtualBox-4.2.10-84104-Linux_amd64.run
# VBox Runtime Linux x32: http://download.virtualbox.org/virtualbox/4.2.10/VirtualBox-4.2.10-84104-Linux_x86.run
# VBox Guest Additions ISO: http://download.virtualbox.org/virtualbox/4.2.10/VBoxGuestAdditions_4.2.10.iso
# VBox Extension Pack: http://download.virtualbox.org/virtualbox/4.2.10/Oracle_VM_VirtualBox_Extension_Pack-4.2.10-84104.vbox-extpack
### PHP Virtual Box Manager v4.2-4
# REF: http://code.google.com/p/phpvirtualbox/
# Remarks: VirtualBox 4.2.x Compatible --- 4.2-4 release
# wget `wget -q -O - http://phpvirtualbox.googlecode.com/files/LATEST.txt` -O phpvirtualbox-latest.zip
# http://phpvirtualbox.googlecode.com/files/phpvirtualbox-4.2-4.zip
# NOTE: These steps were performed on a system after a 'Factory Default' was performed. Therefore, you may experience conflicts that I did not have during my VBox travels.
### Section A: Clean APT Repository, remove locks, and clear all cached deb files
### Update Sources.list ###
### Section B: Install VirtualBox Development Framework
# Setup the Build Environment
### Report System Data ###
uname -r && uname -m
## Full Name: 2.6.37.6.RNx86_64.2.4
## Kernel Series: 2.6.37.6
## Kernel Base: x86_64
## but, system is based on x86_32 (80386)
readelf -h $(which apt-get)|grep -E "Class|Machine"
## This means, for things other than kernel modules
## you need to install x86, 32 bit binaries
# Display HD Raid Device Info
mdadm --misc -D /dev/md0
sudo lvdisplay
mount
# Add local libraries to System
## Install file [5.12] (upgrades libmagic)
# http://freecode.com/projects/file
# The version of libmagic installed on the ReadyNAS is a limited version
# that does not support text or encoding checks, and does not define
# MAGIC_NO_CHECK_TEXT and MAGIC_NO_CHECK_ENCODING.
# Later on we will use python to link libmagic to python apps
# Make sure you link file and libmagic with python even if you already have python installed
## Install xz-Utils [5.0.4]
## Update gZxx [1.5] [1.3.12 is installed]
# Installs ~ gzip/gunzip/gzexe
## Update Bash [4.2] [3.1.17 is installed]
## Install fuseiso because iso capability is not compiled into ReadyNAS Kernel
# Using fuseiso on a simple iso file. With the -p option, you do not need to create the mount point directory
# The mount point dir will be created when the iso is mounted and automatically removed when its unmounted
# mounting: fuseiso -p testimage.iso testimage_mountpoint
# unmounting: fusermount -u testimage_mountpoint
# To avoid the automatic indexing of a mounted iso add "fuse.fuseiso" to the end of the PRUNEFS="..." declaration
# This should prevent the updatedb/locate database from indexing mounted iso files
nano /etc/updatedb.conf
>> Line 7: PRUNEFS="NFS nfs nfs4 afs binfmt_misc proc smbfs autofs iso9660 ncpfs coda devpts ftpfs devfs mfs shfs sysfs cifs lustre_lite tmpfs usbfs udf fuse.fuseiso"
## Update Logger
## Replace missing script usually found on debian systems
nano /etc/mysql/debian-start
## Install Python [2.7.3] [skip if Python is already installed, but be sure to connect libmagic]
# For compatibility, make sure your python version does not exceed sabnzbd/couchpotato/sickbeard requirements
## Link Apache2 to Frontview
## Install Php5 [5.3.22] [skip if Php5 is already installed]
## Install phpMyAdmin 3.5.7 [If already installed, remove your version of phpMyAdmin and follow these steps]
## Setup phpMyAdmin to work with MySQL by using Wizard at URL
## NOTE: If you changed the MySQL User Root password
## Log into mysql as root and set it back to nothing ~ an empty password
mysql -uroot -p
mysql> UPDATE mysql.user SET Password=PASSWORD('') WHERE User='root';
mysql> FLUSH PRIVILEGES;
mysql> \q
## > Goto URL: https://ReadyNAS_IP_Address/phpmyadmin/setup/
## Click on the <New Server> Button
## Look at /etc/mysql/my.cnf
## This will help set the
## Server configuration
## Your will see "Add a new server" {Basic settings} TAB
## [SELECT] <New Server>
## "Add a new server" {Basic settings} TAB
## Verbose Name of Server: ReadyNAS Ultra
## Server Hostname: localhost
## Server Port: 3306
## Server Socket: /var/run/mysqld/mysqld.sock
## Connection Type: socket
## PHP Ext to use: mysql
## Connect without password: Checked
## "Add a new server" {Server configuration} TAB
## Allow root login: Checked
## Allow logins without a password: checked
## <save>
## <save>
## Look for "Configuration saved" message
## Configuration saved to file config/config.inc.php in phpMyAdmin top level directory ...
## If you don't see this message, start over
## Close Browser Window
# Restart Services
## Test phpMyAdmin using root with no password
## > Goto URL: https://ReadyNAS_IP_Address/phpmyadmin/index.php
## Username: root
## Password:
## <GO>
# you should see these databases or more: information_schema, mysql, and slimserver
## Install ReadyNAS {Photos II} addon to activate MySQL Server during boot
## Clear /root/src to avoid inode space issues
### Section C: Build and Patch the Kernel
### Compile new Kernal with VBOX Modules
# The Kernel must be built on the /c/ drive
# to avoid space limitations of the root directory.
### Section C1: Download the Kernel Patch Kit
### Get ReadyNAS Kernel-Build-Tools (Published: 4OCT12)
# Using RNDP6xxx_4.2.22_WW_src.zip
# http://www.readynas.com/download/GPL/RNDP6xxx_4.2.22_WW_src.zip
# NetGear makes a Kernel-Build-Tools set of patches to convert a Kernel.org Tar.bz2 source
# into a kernel capable of working on the ReadyNAS Hardware Box [buttons, lcd, fan control, etc]
# Note: There is only one kernel tree included in the RNDP6xxx_4.2.22_WW_src.zip file ~ 2.6.37.6.
### Download ReadyNAS Kernel-Build-Tools
### Section C2: Build VirtualBox Kernel Environment
## Align Kernel Tree with Debian System
## Setup the Build Process for a ReadyNAS Kernel
## You have finished the ReadyNAS 2.6.37 basic kernel build
### Section D: Install VirtualBox-4.2.10-84104
### Note: Python must be installed and working before continuing ###
# Download VBox Runtime and Ext Pack
## Make sure System is Clean from prior install
## Install VBox Runtime with source code for VBox Kernel modules
# This creates the '/opt/VirtualBox' directory and compiles VBox kernel modules
# A user's manual can be found at '/opt/VirtualBox/UserManual.pdf'
## Fix error while loading shared libraries: libcrypt.so.1
# Apparently, the 32-bit libcrypt.so is in the root image, but not the 64-bit one.
# Install VirtualBox Extension Pack
# Setup default VirtualMachine folders of VBox
# I store all original downloaded VM's into backup/images (leave compressed)
# I store all downloaded VM's into importimage that I'm using in VBox (uncompressed)
# I save all VBox exported VM's into exportimage (give them to all your friends)
# Using linked directories, put the VBox Guest Additions ISO into a location that is searched by the phpVirtualBox Manager
# Compile VirtualBox kernel modules
# Copy VBox Modules into the directory matching your kernel release from uname -r
# If you have RAIDiator 4.2.22 installed, it should match 2.6.37.6.RNx86_64.2.4
# Force VBox Kernel module recompile - just to be sure everything worked.
# If Errors, Please have a look at /var/log/vbox-install.log to find out why the compilation failed
### Test VBox System for Driver Install ###
### End Test
## Backup Kernal Directory into a TAR file named "VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.22.tar"
## SKIP; unless you need to Restore the backup you just made
mkdir /c/addons-config/VirtualBox/kernel
mkdir /c/addons-config/VirtualBox/kernel/2.6.37/
cd /addons-config/VirtualBox/backup
tar xf VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.22.tar -C ../kernel/2.6.37/
### Section E: Install phpVirtualBox and FSniper
# phpVirtual Box allows you to work with your ReadyNAS VirtualBox from a web browser
# It is an open source, AJAX implementation of the VirtualBox user interface written in PHP.
# As a modern web interface, it allows you to access and control remote VirtualBox instances.
# Much of its verbiage and some of its code is based on the (inactive) vboxweb project.
# phpVirtualBox was designed to allow users to administer VirtualBox in a headless environment
# - mirroring the VirtualBox GUI through its web interface.
### Note: PHP must be installed and working before continuing ###
## Six (6) Easy Steps: This will surely get you to Narnia or Never Never Land
## You should complete Steps [1 - 4]. However, Steps [5 - 6] are optional.
# Let's get this party started
## Step 1: Add Users to VBoxUsers Group
## Sample Output:
# Adding user `vbox' ...
# Adding new user `vbox' (1005) with group `vboxusers' ...
# >> Not creating home directory `/home/vbox'.
# Enter new UNIX password:
# Retype new UNIX password:
# passwd: password updated successfully
# Changing the user information for vbox
# >> Enter the new value, or press ENTER for the default
# Full Name []: vbox
# Room Number []:
# Work Phone []:
# >> Home Phone []:
# Other []:
# >> Is the information correct? [Y/n]
# Give User vbox ownership of Image Storage Directories
## Step 2: Install PHP VirtualBox Manager for ReadyNAS
# Download PHPVBoxMgr_0.4-readypro-0.1.1.bin
# Site: http://netgear.tonidoid.com/app/webshare/share/NETGEAR%20ReadyNAS%20Tech%20Documents/Add-on/x86/?vm=list
## Create addons-config Share using FrontView:
# FrontView: [Shares] [Add Shares] [Name: addons-config] [Description: Addons-config Share] [Apply]
# FrontView: [Share Listing] [CIFS ~ addons-config] [Advanced Options] [Owner: nobody] [Group: nogroup] [Rights: Reade/write] [Permissions: [x][x]] [Apply]
## Install PHPVBoxMgr using FrontView:
# FrontView: [Add-ons][Add New] then [Browse]: \\ReadyNAS_IP_Address\addons-config\VirtualBox\backup
# <Select>: PHPVBoxMgr_0.4-readypro-0.1.1.bin
# FrontView: [Upload and verify image..][Warning][OK] then [Install]
# FrontView: [Add-ons][Installed] -> Verify that you see PHPVBoxMgr
# Do not attempt to Edit or [Load Config] from FrontView's VirtualBox Manager
## Step 3: Upgrade PHP VirtualBox Manager from v0.4 to v4.2-4
### *** PHP Virtual Box Manager v4.2-4 *** ###
# Download Latest version of PHP VirtualBox Manager:
## Step 4: Edit PHP VirtualBox Manager Configuration File
# Location of file: /frontview/ui/resource/html/phpvboxmgr/config.php
# There is a bug in 4.2-4 that prevents the <console> preview from working, add line 14 to fix.
# Edit Instructions:
: nano /frontview/ui/resource/html/phpvboxmgr/config.php
>> Line 12: var $username = 'vbox'; vbox is the username you created in step 3 above;
>> Line 13: var $password = 'xxx'; where xxx is the password you created in step 3 above;
>> Line 14: var $consoleHost = 'ip.address.of.ReadyNAS';
>> Line 175: var $enableAdvancedConfig = true; remove the # to activate this feature;
>> Line 181: var $startStopConfig = true; remove the # to activate this feature;
## Step 5: Install fsniper to make life even more easier: This is Genius. Pure Genius!
# Fsniper is a directory monitor that can be used to execute predefined actions on files that enter the monitored directory.
# This can, for example, be used to monitor your downloads folder and sort downloaded files automatically into your file system.
# Unlike cron jobs or bash scripts, fsniper uses inotify to monitor file changes.
# This enable it to react immediately and efficiently to changes of the file system.
# Common uses include making a single drop directory and having semi-intelligent scripts figure out what to do with those files.
# More information can be found at the sources below:
# Source 1: http://blog.secaserver.com/2011/06/fsniper-monitor-newly-created-files-in-directory/
# Source 2: https://wiki.archlinux.org/index.php/Fsniper
# Source 3: http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fwww.ruderwiki.de%2Fwiki_neu%2Findex.php%2FEfa_unter_Linux
# We will use fsniper to automatically make VBox the owner of image files placed in the
# /addons-config/VirtualBox/VirtualMachines/importimage directory and to automatically
# unpack files placed in the VBox backup image directory.
# I place all images from the iNet into the /addons-config/VirtualBox/VirtualMachines/importimage directory.
# For example, I get ClearOS VBox images from http://www.clearfoundation.com/Software/downloads.html
# You can also find a plethora of images from http://virtualboxes.org/images
# The "sudo sh -c" line creates the fsniper config file. Copy and past all at once into your terminal screen.
# The 'EOF' tells sh to stop reading. You may have to hit <Enter> after you pasted the code to close the file.
# All comments are placed in the fsniper log file: /root/.config/fsniper/log
# fsniper will not notice the file until it is unpacked from the tar/7z/zip/rar container.
# Added Bonus, VDI files are automatically compressed to make them smaller.
# Remember this will be done only once when a *.vdi file is first placed into the directory.
# Edit the fsniper config file to do what you want it to do - No worries, Be Happy!
# The fsniper file will be placed in /usr/local/bin
##Step 6: Install dameontools to make life even more easier
# daemontools is a collection of tools for managing UNIX/Linux services.
# Services created with daemontools will restart automatically if stopped
# Source: http://www.bytereef.org/howto/djb/daemontools-install.html
# Source: http://cr.yp.to/daemontools.html
# Install Daemontools
# This will install supervise, svc, svok, svscan, svscanboot, and svstat into /usr/sbin
# Install Daemontools Man Pages:
# Install fsniper as an automatic service
nano /etc/init.d/fsniper
# Advantage: if stopped, daemontool services automatically restart without using cron or inittab
# Check to make sure Daemontools are running
ps -ef | grep svscan && ps -ef | grep supervise
# Sample Output:
# >> root 7761 1 0 10:04 ? 00:00:00 /bin/sh /usr/sbin/svscanboot
# >> root 7763 7761 0 10:04 ? 00:00:00 svscan /service
### Section F: Starting the VirtualBox ReadyNAS Server
# This is your moment of Happiness not Happyness - Can you name the movie?
# This allows VirtualBox to run as user 'vbox'
# Check that root owns the /opt Directory
ls -ld /opt
# Execute this line again if you ever get the error: "Failed to load VMMR0.r0"
# Create VBox Web User ID for VBox Web Server Daemon
# Give root Permission to Start the VBox Server as user 'vbox'
## Automatically Start Virtual Machines within VBox
# VBox will start automatically due to daemons vboxdrv and vboxweb-service
# /etc/init.d/vboxdrv loads VBox Kernel drivers into memory
# /etc/init.d/vboxweb-service starts the VBox Web Server
# This step allows VM's that are installed into VBox to start Automatically when your ReadyNAS boots
# NOTE: This is related to Step 4, line 181.
# For this to work, the VM's 'Startup Mode' must be set to 'automatic'
# Sample Output:
# >> Adding system startup for /etc/init.d/vboxinit ...
# >> /etc/rc0.d/K20vboxinit -> ../init.d/vboxinit
# >> /etc/rc1.d/K20vboxinit -> ../init.d/vboxinit
# >> /etc/rc6.d/K20vboxinit -> ../init.d/vboxinit
# >> /etc/rc2.d/S20vboxinit -> ../init.d/vboxinit
# >> /etc/rc3.d/S20vboxinit -> ../init.d/vboxinit
# >> /etc/rc4.d/S20vboxinit -> ../init.d/vboxinit
# >> /etc/rc5.d/S20vboxinit -> ../init.d/vboxinit
## Start your VBox Engine
## Start VBox Driver Service ##
## Start VBox Web Server ##
# NOTE: VBox does not use the ReadyNAS Apache Web Server
# The VBox Web Server allows you to access the PHP VBox Manager
## Here are some ways to Check on the VBox Web Server that is running on port 18083
netstat -an|grep 18083
# >> # tcp 0 0 127.0.0.1:18083 0.0.0.0:* LISTEN
netstat -lpn | grep 18083
# >> # tcp 0 0 127.0.0.1:18083 0.0.0.0:* LISTEN 17344/vboxwebsrv
# The 17344 represents the PID of the process that owns port 18083
ps axfu | grep 17344
# >> # vbox 17344 0.2 0.2 200476 10476 ? Sl 10:34 0:50 /opt/VirtualBox/vboxwebsrv --background
# We know that VBox's web server was started by /etc/init.d/vboxweb-service start or restart
# However, did you know that it actually issued this command "/opt/VirtualBox/vboxwebsrv --background"
# Easiest way to show VBox Server Info
## Start the "Automatically Start Virtual Machines" Service
# Fix corrupted vboxinit
## [Reboot] ReadyNAS
## Accessing PHP VirtualBox Manager: http://IP_of_your_ReadyNAS_Box/phpvboxmgr
## Note: Not sure why, but my first attempt to login using PHP VirtualBox Manager required an ID/PW of admin/admin.
# The user was 'admin' not 'vbox'. I then used [File] -> [Preferences] -> [Users] to add User 'vbox' as an (Admin User).
# At this point, you should logout and log back in as User 'vbox' and [Delete] User 'admin'.
# If you get a PHP soap error, install php-soap then remove the ';' from the extension=php_soap.dll entry in php.ini
sudo apt-get install php-soap
nano /usr/local/lib/php.ini
>> line 991: extension=php_soap.dll
reboot
## Change the default VirtualMachine folder of VBox
# 1) Using the command line
: VBoxManage setproperty machinefolder "/c/addons-config/VirtualBox/VirtualMachines/working"
# 2) Using a web Browser:
# Access: http://IP_of_your_ReadyNAS_Box/phpvboxmgr/
# Check this just to be sure: [Preferences] -> [General] -> [Default Machine Folder]: /c/addons-config/VirtualBox/VirtualMachines/working
# If everything worked, you should have a smile on your face:)
# You can also manually start the VBox Web Server using '/opt/VirtualBox/vboxwebsrv'
# I run it this way to trouble-shoot vbox permission issues.
Virtual Machine Ideas:
1. ClearOS Firewall (Great due to 2x Ethernet ports: http://www.clearcenter.com/Software/clearos-professional-downloads.html)
> although written for IPCop in a VM, this related discussion may help with ip/port setup and configuration ( http://greenpossum.awardspace.com/ipcop-in-vbox.html)
2. Music Brainz Server (http://musicbrainz.org/doc/MusicBrainz_Server/Setup)
> Network Settings:Bridged Adapter, eth0, Intel PRO/1000 MT Desktop
> username: musicbrainz password: musicbrainz
> sudo ~/run_replication.sh
> ifconfig | grep eth0 -A 1
> ~/run_server.sh
> Access: http://current.ReadyNAS.ip.address:5000
3. Kolab Server 3.0 (http://kolab.org/get-kolab)
4. Android 4.0 (http://www.kirsle.net/blog/kirsle/android-4-0-in-virtualbox)
5. ChromimumOS (http://chromeos.hexxeh.net/)
> Instructions @ http://www.androidauthority.com/howto-test-drive-chrome-os-features-the-chromium-way-155084/
6. Amahi Server 6.1, Ubuntu 12.04 or Fedora 14 (http://www.amahi.org/)
> for Ubuntu 12.04 build a VM (http://blog.coolaj86.com/articles/how-to-install-ubuntu-in-virtualbox.html)
and follow this process (http://docs.amahi.org/ubuntu-12.html)
7. Synology DSM 4.1 (http://xpenology.com/forum/viewtopic.php?f=2&t=3&sid=c766ced785bd2610629e8b24bddd3d45)
8. Windows 8 (http://www.youtube.com/watch?v=u5rk4E-5yVU)
### VBox: 4.2.10
### with new users.
### Thanks
mv /etc/apt/sources.list /etc/apt/sources.list.bak
rm -rf /etc/apt/sources.list
sudo sh -c "cat >> /etc/apt/sources.list" <<EOF
deb http://www.readynas.com/packages readynas-x86/
deb http://www.readynas.com/packages 4.2.21/
deb http://www.readynas.com/packages 4.2.22/
deb http://archive.debian.org/debian etch main
deb http://packages.dotdeb.org stable all
deb-src http://packages.dotdeb.org stable all
deb http://php53.dotdeb.org stable all
deb-src http://php53.dotdeb.org stable all
#deb http://download.virtualbox.org/virtualbox/debian squeeze contrib non-free
#deb http://backports.debian.org/debian-backports squeeze-backports main contrib non-free
EOF
gpg --keyserver pgpkeys.mit.edu --recv-key E9C74FEEA2098A6E && gpg -a --export E9C74FEEA2098A6E | sudo apt-key add -
gpg --keyserver pgpkeys.mit.edu --recv-key 54422A4B98AB5139 && gpg -a --export 54422A4B98AB5139 | sudo apt-key add -
gpg --keyserver pgpkeys.mit.edu --recv-key AED4B06F473041FA && gpg -a --export AED4B06F473041FA | sudo apt-key add -
# Setup Root Directory Source Area
mkdir /root/src
mkdir /root/system
# Save Key System Files
cp /etc/apt/sources.list* /root/system
cp /etc/host* /root/system
cp /etc/resolv.conf /root/system
cp /etc/passwd /root/system
cp /etc/sudoers /root/system
cp /frontview/conf/enclosure.db /root/system
### Refresh Packages from the APT repository ~ may help remove BADSIG messages ###
# Clear the APT Repositories
sudo killall apt apt-get aptitude
sudo -s -H
apt-get clean
rm -rf /var/lib/apt/lists/*
chmod 755 /var/lib/apt/lists
mkdir /var/lib/apt/lists/partial
chmod 755 /var/lib/apt/lists/partial
rm -rf /var/cache/apt/archives
mkdir -p /var/cache/apt/archives/partial
apt-get clean
# Replace File Locks
rm -rf /var/lib/dpkg/lock
sudo touch /var/lib/dpkg/lock
sudo chmod 640 /var/lib/dpkg/lock
rm -rf /var/lock/aptitude
sudo touch /var/lock/aptitude
sudo chmod 640 /var/lock/aptitude
rm -rf /var/lib/apt/lists/lock
sudo touch /var/lib/apt/lists/lock
sudo chmod 640 /var/lib/apt/lists/lock
rm -rf /var/cache/apt/archives/lock
sudo touch /var/cache/apt/archives/lock
sudo chmod 640 /var/cache/apt/archives/lock
# Freshen up APT Repository Packages
# Say [Y/n] 'y'es to continue.
apt-get update
# Install Basic apps
apt-get install nano curl gettext gawk noflushd dpkg-dev
# Fix noflushd
# This changes TIMEOUT from empty to =30
sed 's/^TIMEOUT=/TIMEOUT=30/' /etc/default/noflushd > /etc/default/noflushd1 \
&& mv /etc/default/noflushd1 /etc/default/noflushd
apt-get -f install && apt-get update
apt-get install build-essential libncurses5-dev libtag1-dev libssl-dev zlibc &&
apt-get install libpcre3-dev libcurl4-openssl-dev &&
apt-get install gdb uuid-dev amd64-libs lib64stdc++6 &&
apt-get install par2 parchive bzip2 gpp p7zip p7zip-full &&
apt-get install git kernel-package fakeroot
sudo lvdisplay
mount
cat /etc/ld.so.conf
echo "/usr/local/lib" >> /etc/ld.so.conf
ldconfig
cd /root/src
wget ftp://ftp.astron.com/pub/file/file-5.12.tar.gz
tar zxf file-5.12.tar.gz
cd file-5.12
./configure
make && make install
mv /usr/bin/file /usr/bin/file.bak
ln -s /usr/local/bin/file /usr/bin/file
echo "/usr/local/lib" > /etc/ld.so.conf.d/magic.conf
ldconfig
file --version
cd /root/src
wget http://tukaani.org/xz/xz-5.0.4.tar.gz
tar zxf xz-5.0.4.tar.gz
cd xz-5.0.4
./configure
echo "/usr/local/lib" > /etc/ld.so.conf.d/lzma.conf
ldconfig
xz --version
cd /root/src
wget http://ftp.gnu.org/gnu/gzip/gzip-1.5.tar.gz
tar -zxf gzip-1.5.tar.gz
cd gzip-1.5
./configure
mv /bin/gzip /bin/gzip.bak
ln -s /usr/local/bin/gzip /bin/gzip
mv /bin/gunzip /bin/gunzip.bak
ln -s /usr/local/bin/gunzip /bin/gunzip
mv /bin/gzexe /bin/gzexe.bak
ln -s /usr/local/bin/gzexe /bin/gzexe
gzip --version
gunzip --version
gzexe --version
cd /root/src
wget http://ftp.gnu.org/gnu/bash/bash-4.2.tar.gz
tar -zxf bash-4.2.tar.gz
cd bash-4.2
./configure
mv /bin/bash /bin/bash.bak
ln -s /usr/local/bin/bash /bin/bash
bash --version
apt-get install build-essential fuse-utils libfuse-dev libglib2.0-dev
cd /root/src
wget --no-check-certificate "https://launchpad.net/ubuntu/+archive/primary/+files/fuseiso_20070708.orig.tar.gz"
tar zxf fuseiso_20070708.orig.tar.gz
cd fuseiso-20070708/
./configure
make install
fuseiso -h
fusermount -h
## Update Logger
cd /usr/binnano logger
ls -aFl logg*
mv logger logger.real
#!/bin/bash
while getopts ":st:p:" Option
do
case ${Option} in
s | t | p ) cmdline="${cmdline} -${Option} ${OPTARG}" ;;
esac
done
shift $((${OPTIND} - 1))
busybox logger "${cmdline}" "${*}"
chmod +x logger
apt-get update
#!/bin/bash#-------------------------------------------------------------------
# This script is executed by "/etc/init.d/mysql" on every (re)start.
# Changes to this file will be preserved when updating the Debian package.
source /usr/share/mysql/debian-start.inc.sh
MYSQL="/usr/bin/mysql --defaults-file=/etc/mysql/debian.cnf"
MYADMIN="/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf"
MYUPGRADE="/usr/bin/mysql_upgrade --defaults-extra-file=/etc/mysql/debian.cnf"
MYCHECK="/usr/bin/mysqlcheck --defaults-file=/etc/mysql/debian.cnf"
MYCHECK_SUBJECT="WARNING: mysqlcheck has found corrupt tables"
MYCHECK_PARAMS="--all-databases --fast --silent"
MYCHECK_RCPT="root"
# The following commands should be run when the server is up but in background
# where they do not block the server start and in one shell instance so that
# they run sequentially. They are supposed not to echo anything to stdout.
# If you want to disable the check for crashed tables comment
# "check_for_crashed_tables" out.
# (There may be no output to stdout inside the background process!)
echo "Checking for corrupt, not cleanly closed and upgrade needing tables."
upgrade_system_tables_if_necessary;
check_root_accounts;
check_for_crashed_tables;
) >&2 &
exit 0
chmod +x /etc/mysql/debian-start
ln -s /etc/mysql/my.cnf /etc/mysql/debian.cnf
cd /root/src
wget http://www.python.org/ftp/python/2.7.3/Python-2.7.3.tgz
tar xzf Python-2.7.3.tgz
cd Python-2.7.3
./configure
make install
echo "/usr/local/lib" > /etc/ld.so.conf.d/python.conf
ldconfig
# Install Python setuptools
cd /root/src
wget http://peak.telecommunity.com/dist/ez_setup.py
python ez_setup.py
python -V
# Connect libmagic to python [5.12]
cd /root/src/file-5.12
cd python && python setup.py install
file --version
# Install Python PiP + beautifulsoup utility
/usr/local/bin/easy_install pip
ln -s /usr/local/bin/pip /usr/bin/pip
pip install -U pip
pip install beautifulsoup4
pip install libmagic
rm -rf /etc/apache
ln -s /etc/frontview/apache /etc/apache
cp -rf /etc/apache2/* /etc/frontview/apache
rm -rf /etc/apache2
ln -s /etc/frontview/apache /etc/apache2
ln -s /etc/frontview/apache /usr/local/apache2
ln -s /etc/frontview/apache/httpd.conf /etc/frontview/apache2.conf
ln -s /etc/frontview/apache/httpd.conf /etc/frontview/apache/apache2.conf
apt-get install byacc automake libtool re2c flex bison &&
apt-get install apache-dev apache2-prefork-dev libbz2-dev libmcrypt-dev &&
apt-get install libmysqlclient-dev libmysqlclient18 mysql-common=5.5.30-1~dotdeb.0 &&
apt-get install libxml2=2.6.27.dfsg-6+etch1 &&
apt-get install libxslt-dev
ln -s /usr/bin/apxs /usr/sbin/apxs
ln -s /usr/bin/apxs2 /usr/sbin/apxs2
updatedb
cd /root/src
rm -rf php5*
apt-get source php5
cd php5-5*
cd pear
wget http://pear.php.net/go-pear.phar
cd ..
./configure --with-apxs2=/usr/sbin/apxs2 \
--prefix=/usr/local/php5 \
--enable-soap \
--with-mysql \
--with-bz2 \
--with-zlib \
--enable-zip \
--enable-mbstring \
--with-mcrypt \
--with-mysqli \
--with-config-file-path=/usr/local/php/php.ini \
--with-config-file-scan-dir=/usr/local
apt-get install php5-common
# Configure PHP5
libtool --finish /root/src/php5-5*/libs
chmod 644 /usr/lib/apache2/modules/libphp5.so
cd /root/src/php5-5*
cp -rf php.ini-development /usr/local/lib/php.ini
#>> Line 796: change {;include_path = ".:/usr/share/php"} to {include_path = "/usr/share/php5:/usr/local/php5/lib/php"}
ln -s /usr/local/lib/php.ini /usr/local/php5/etc/php.ini
/root/src/php5-5.3.22/build/shtool install -c /root/src/php5-5.3.22/ext/phar/phar.phar /usr/local/php5/bin
ln -s -f /usr/local/php5/bin/phar.phar /usr/local/php5/bin/phar
/usr/local/php5/bin/php -v
ln -s /usr/local/php5/bin/pear /usr/bin/pear
ln -s /usr/local/php5/bin/peardev /usr/bin/peardev
ln -s /usr/local/php5/bin/pecl /usr/bin/pecl
ln -s /usr/local/php5/bin/phar /usr/bin/phar
ln -s /usr/local/php5/bin/php /usr/bin/php
ln -s /usr/local/php5/bin/php-config /usr/bin/php-config
ln -s /usr/local/php5/bin/phpize /usr/bin/phpize
php -v
cd /root/src
wget http://downloads.sourceforge.net/project/phpmyadmin/phpMyAdmin/3.5.7/phpMyAdmin-3.5.7-all-languages.tar.gz
tar zxf phpMyAdmin-3.5.7-all-languages.tar.gz
mv phpMyAdmin-3.5.7-all-languages /frontview/ui/resource/html/phpmyadmin
# Who owns Apache?
egrep 'User|Group' /usr/local/apache2/httpd.conf
#>> Results: User:admin Group:admin
grep DocumentRoot /usr/local/apache2/httpd.conf
#>> Results: DocumentRoot /frontview/ui/resource/html
# Setup phpMyAdmin config
cd /frontview/ui/resource/html
chown -R admin.admin phpmyadmin/
cd phpmyadmin
mkdir config
chmod o+rw config
cp config.sample.inc.php config/config.inc.php
chmod o+w config/config.inc.php
# Restart Services
/etc/init.d/mysql restart
/etc/init.d/apache2 restart
## Temp Start MySQL Service
start-stop-daemon -S -q -b -x /usr/sbin/mysqld -- \
--basedir=/usr \
--datadir=/var/lib/mysql \
--pid-file=/var/run/mysqld/mysqld.pid \
--skip-locking \
--socket=/var/run/mysqld/mysqld.sock
mysql -uroot -p
mysql> \q
## <save>
## <save>
cp /etc/mysql/my.cnf /etc/mysql/my.cnf.bak
cd /frontview/ui/resource/html/phpmyadmin
cp -rf config/config.inc.php .
cp -rf config/config.inc.php /root/system
rm -rf config
# Restart Services
--basedir=/usr \
--skip-locking \
## Username: root
## Password:
## <GO>
df && df -i
cd ~
rm -rf /root/src/*
reboot
mkdir /c/addons-config/VirtualBox/backup
# Install Oracle Key from source
cd /c/addons-config/VirtualBox/backup
wget http://download.virtualbox.org/virtualbox/debian/oracle_vbox.asc
sudo apt-key add oracle_vbox.asc
apt-get update
rm -rf kernel
wget http://www.readynas.com/download/GPL/RNDP6xxx_4.2.22_WW_src.zip
unzip -q RNDP6xxx_4.2.22_WW_src.zip "kernel/*"
mv kernel ..
## Make a copy of umodified ReadyNAS Linux Kernel Source
cd /c/addons-config/VirtualBox/kernel/2.6.37
cp -rf linux-2.6.37.6 ./linux-2.6.37.6-original
# This will save time if you need to start again
# : cd /c/addons-config/VirtualBox/kernel/2.6.37 && rm -rf linux-2.6.37.6 && cp -rf linux-2.6.37.6-original linux-2.6.37.6
## Apply NetGear patches to ReadyNAS 2.6.37.6 Kernel Code
: cd /c/addons-config/VirtualBox/kernel/2.6.37/linux-2.6.37.6/
: chmod +x ../netgearize_kernel.sh
: ../netgearize_kernel.sh
rm -rf /usr/src/linux
ln -snf `pwd` /usr/src/linux
export KERN_DIR=/usr/src/linux
## Link Linux headers to build modules properly
cd /usr/src/linux/include/linux
ln -s ../generated/autoconf.h .
ln -s ../generated/utsrelease.h .
rm -rf /usr/src/linux-headers-2.6.37.6.RNx86_64.2.4/
ln -s /usr/src/linux /usr/src/linux-headers-$(uname -r)
cd /lib/modules/$(uname -r)
rm -rf build
rm -rf source
ln -s /usr/src/linux-headers-$(uname -r) source
ln -s /usr/src/linux-headers-$(uname -r) build
: cp arch/x86/configs/defconfig.smp .config
: make ARCH=x86_64 oldconfig
: make prepare
: make modules_prepare
## Start the Build!
: make
: make -C /lib/modules/`uname -r`/build modules
wget http://download.virtualbox.org/virtualbox/4.2.10/VirtualBox-4.2.10-84104-Linux_amd64.run
wget http://download.virtualbox.org/virtualbox/4.2.10/Oracle_VM_VirtualBox_Extension_Pack-4.2.10-84104.vbox-extpack
chmod 755 VirtualBox-4.2.10-84104-Linux_amd64.run
: ./VirtualBox-4.2.10-84104-Linux_amd64.run uninstall
: rm -rf /opt/VirtualBox
: chown -R root:root /opt
: rm -rf /root/.VirtualBox
: rm -rf /etc/vbox
: rm -rf /home/vbox
: rm -rf /usr/src/vboxhost*
: rm -rf /var/log/vbox-*.log
: rm -rf /etc/init.d/vbox*
: rm -rf /etc/default/virtualbox
: rm -rf /usr/share/virtualbox
: cd /c/addons-config/VirtualBox/backup
: apt-get --reinstall install libc6-amd64
: /usr/bin/VBoxManage extpack uninstall "Oracle VM VirtualBox Extension Pack"
: /usr/bin/VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-4.2.10-84104.vbox-extpack
mkdir /c/addons-config/VirtualBox/backup/images
mkdir /c/addons-config/VirtualBox/backup/images/unpacked
mkdir /c/addons-config/VirtualBox/VirtualMachines
mkdir /c/addons-config/VirtualBox/VirtualMachines/importimage
mkdir /c/addons-config/VirtualBox/VirtualMachines/exportimage
mkdir /c/addons-config/VirtualBox/VirtualMachines/working
# Allow Windows File Service access
chown -R nobody:nogroup /c/addons-config/VirtualBox/backup
chown -R nobody:nogroup /c/addons-config/VirtualBox/kernel
chown -R nobody:nogroup /c/addons-config/VirtualBox/VirtualMachines
: ln -snf /opt/VirtualBox/additions /usr/share/virtualbox
cd /usr/src/vboxhost-4.2.10
make
ls -aFl
uname -r
cp *.ko /lib/modules/`uname -r`/
cp *.ko /lib/modules/`uname -r`/kernel/drivers/target/
: sudo /etc/init.d/vboxdrv setup
# Stop VirtualBox Service
/etc/init.d/vboxdrv stop
# Start VirtualBox Service
/etc/init.d/vboxdrv restart
### End Test
cd ../ && tar -cf /c/addons-config/VirtualBox/VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.22.tar linux-2.6.37.6/ && cd linux-2.6.37.6/
mv /addons-config/VirtualBox/VBox_Linux_Kernel_2.6.37.6_ReadyNAS_4.2.22.tar /addons-config/VirtualBox/backup
rm -rf /c/addons-config/VirtualBox/kernel
adduser vbox --no-create-home --ingroup vboxusers
## Sample Output:
# Room Number []:
# Work Phone []:
# >> Home Phone []:
# Other []:
adduser vbox vboxusers
chown vbox:vboxusers ./VirtualMachines/
chown vbox:vboxusers ./VirtualMachines/importimage/
chown vbox:vboxusers ./VirtualMachines/exportimage/
chown vbox:vboxusers ./VirtualMachines/working/
wget http://netgear.tonidoid.com/app/webshare/share/NETGEAR%20ReadyNAS%20Tech%20Documents/Add-on/x86/PHPVBoxMgr_0.4-readypro-0.1.1.bin?action=download
mv PHPVBoxMgr_0.4-readypro-0.1.1.bin\?action\=download PHPVBoxMgr_0.4-readypro-0.1.1.bin
rm -rf phpvirtualbox*
unzip phpvirtualbox-latest.zip
cp /frontview/ui/resource/html/phpvboxmgr/config.php /addons-config/VirtualBox/backup/phpvirtualbox-4.2-4/config.php.bak
mv /addons-config/VirtualBox/backup/phpvirtualbox-4.2-4/config.php-example /addons-config/VirtualBox/backup/phpvirtualbox-4.2-4/config.php
: rm -rf /frontview/ui/resource/html/phpvboxmgr/
: cp -rf /addons-config/VirtualBox/backup/phpvirtualbox-4.2-4 /frontview/ui/resource/html/phpvboxmgr
rm -rf fsniper-1.3.1
wget http://projects.l3ib.org/fsniper/files/fsniper-1.3.1.tar.gz
tar -xzf fsniper-1.3.1.tar.gz
cd fsniper-*
sudo ./configure
sudo make
sudo make install
fsniper --version
killall fsniper
rm -rf /root/.config
fsniper
killall fsniper
touch /root/.config/fsniper/log
sudo sh -c "cat >> /root/.config/fsniper/config" <<EOF
watch {
# Let's watch My Vbox backup image directory
# Unpacked all storage containers
/addons-config/VirtualBox/backup/images {
recurse = false
# lets monitor based on file ext
*.7z {
handler = echo New 7z %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; 7za e %%
*.bz2 {
handler = echo New bz2 %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; bunzip2 -k %%
*.tar.gz {
handler = echo New tar.gz %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; tar -zxvf %%
*.tgz {
handler = echo New tgz %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; gunzip -c %% | tar -xvf -
*.rar {
handler = echo New rar %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; unrar e %%
*.tar {
handler = echo New tar %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; tar -xf %%
*.zip {
handler = echo New zip %% File Detected; cd /addons-config/VirtualBox/backup/images/unpacked; unzip %%
# Move unpacked files to the vBox importimage directory
/addons-config/VirtualBox/backup/images/unpacked {
recurse = true
*.ova {
handler = echo Moving OVA %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vdi {
handler = echo Moving VDI %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vmdk {
handler = echo Moving VMDK %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vhd {
handler = echo Moving VHD %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.vbox {
handler = echo Moving VBOX %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
*.hdd {
handler = echo Moving HDD %% Image File; mv %% /addons-config/VirtualBox/VirtualMachines/importimage
# Let's watch the VBox import image directory
# Make sure all images are owned by User VBox in group VBoxUsers
/addons-config/VirtualBox/VirtualMachines/importimage {
recurse = false
*.ova {
handler = echo New IMPORT OVA %% File Detected; chown vbox:vboxusers %%
*.vdi {
handler = echo New IMPORT VDI %% File Detected; chown vbox:vboxusers %%
*.vmdk {
handler = echo New IMPORT VMDK %% File Detected; chown vbox:vboxusers %%
*.vhd {
handler = echo New IMPORT VHD %% File Detected; chown vbox:vboxusers %%
*.vbox {
handler = echo New IMPORT VBOX %% File Detected; chown vbox:vboxusers %%
*.hdd {
handler = echo New IMPORT HDD %% File Detected; chown vbox:vboxusers %%
# Not related to VBox - This is for my movies and TV Shows
/c/media/Video/Movies/New {
recurse = true
*.mkv {
handler = echo New Movie %% Detected; cd /c/media/Video/Movies/New; rmcleanvideoextra; chown nobody:nogroup %%
*.avi {
*.mpg {
*.mpeg {
*.mp4 {
EOF
rm -rf daemontools
mkdir daemontools && cd daemontools
wget http://cr.yp.to/daemontools/daemontools-0.76.tar.gz
wget http://smarden.org/pape/djb/manpages/daemontools-0.76-man.tar.gz
wget http://www.rickwidmer.com/software/netqmail-1.06.tar.gz
wget http://thedjbway.b0llix.net/patches/daemontools-0.76.sigq12.patch
tar xzf daemontools-0.76.tar.gz
tar xzf netqmail-1.06.tar.gz
cp netqmail-1.06/other-patches/daemontools-0.76.errno.patch .
cd admin/daemontools-0.76
patch -Np1 -i ../../daemontools-0.76.errno.patch
patch -Np1 -i ../../daemontools-0.76.sigq12.patch
package/compile
cd package
sed 's|/command|/usr/sbin|' boot.inittab > boot.inittab~ &&
mv -f boot.inittab~ boot.inittab &&
cd ../command &&
sed -e 's|/command:/usr/local/bin:/usr/local/sbin:||' \
-e 's|/command/svc|/usr/sbin/svc|' svscanboot > svscanboot~ &&
mv -f svscanboot~ svscanboot &&
chmod +x svscanboot &&
/bin/cp * /usr/sbin &&
cd ../package &&
cat /etc/inittab boot.inittab > /etc/inittab~ &&
mv -f /etc/inittab~ /etc/inittab &&
mkdir /service &&
telinit q
apt-get install man
cd /c/addons-config/VirtualBox/backup/daemontools
tar xvzf daemontools-0.76-man.tar.gz
cd daemontools-man
gzip *.8
cp *.8.gz /usr/share/man/man8
killall fsniper
rm -rf /etc/init.d/fsniper
export HOME=/root
PID=$(pidof -o %PPID /usr/local/bin/fsniper)
case "$1" in
start)
echo -n "Starting Fsniper: "
/usr/local/bin/fsniper --daemon
echo -e "... [OK]"
stop)
echo -n "Stopping Fsniper: "
[ ! -z "$PID" ] && kill -9 `ps aux | grep "fsniper" | grep -v grep | awk {'print $2'}` > /dev/null
if [ $? -gt 0 ]; then
echo -e "It is not running!"
else
echo -e "... [OK]"
fi
restart)
$0 stop
sleep 1
$0 start
echo "Usage: `basename $0` start|stop|restart"
exit 1
esac
exit 0
chmod 755 /etc/init.d/fsniper
/etc/init.d/fsniper start
killall fsniper supervise svscanboot
rm -rf /service
mkdir /service
mkdir /service/fsniper
sudo sh -c "cat >> /service/fsniper/run" <<EOF
#!/bin/sh
echo starting Fsniper using daemontools
touch ~/.config/fsniper/log
exec /etc/init.d/fsniper start
EOF
chmod 755 /service/fsniper/run
# Sample Output:
ls -ld /opt
: chown root /opt
: echo "VBOXWEB_USER=vbox" >> /etc/default/virtualbox
: rm -rf /home/vbox
: mkdir /home/vbox
: chown vbox:vboxusers /home/vbox
: mkdir /home/vbox/.VirtualBox/
: chown vbox:vboxusers /home/vbox/.VirtualBox
: login vbox
: VBoxManage setproperty websrvauthlibrary null
: VBoxManage setproperty machinefolder "/c/addons-config/VirtualBox/VirtualMachines"
: exit
: cp /frontview/ui/resource/html/phpvboxmgr/vboxinit /etc/init.d
: chmod u+rx /etc/init.d/vboxinit
: sudo chown root /etc/init.d/vboxinit
update-rc.d vboxinit defaults
# Sample Output:
: /etc/init.d/vboxdrv restart
: /etc/init.d/vboxweb-service restart
vboxwebsrv -b
apt-get install sysutils
: dos2unix /etc/init.d/vboxinit
: /etc/init.d/vboxinit restart
: chown root /opt
reboot
> ~/run_server.sh
