chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Jul 20, 2013Apprentice
That's strange. Are /etc/apache and /etc/apache2 softlinks links on your NAS? Matty's instructions said to create those. If they are there then I don't see how it worked. The tar command to extract the new image fails every time. Unless an ultra2+ has a different install image that doesn't include those directories? The Pro-6 uses the x86 image. I thought the atom based systems would use the same one, but maybe that's not the case or for some reason those files don't get laid down on the ultra2+. The files it lays down did not change with the release. I believe they were these three in /etc/apache2/mods-available: apreq.load, auth_sys_group.load, and perl.load.
steve
steve
