chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Jul 20, 2013Apprentice
Oh, I think his original instructions had the linking inside the php install instructions so if you already had php then maybe you didn't have the links. I'm not sure what the consequences are of not consolidating the apache locations. Maybe it's not necessary if you haven't had problems.
