chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sander11
Jul 22, 2013Aspirant
What is involved in upgrading the firmware with virtualbox installed? Do you have to do the whole re-install or just the kernel modules?
I recall upgrading the firmware back when I ran vmware server and it "just worked".
TIA
TIA
