chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
JamieSinn
Aug 12, 2013Aspirant
I get this error whenever i try to update and or install virtualbox
Can anyone help?
Server:/lib/modules/2.6.37.6.RNx86_64.2.4/misc# apt-get install virtualbox-2.1
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
virtualbox-2.1: Depends: libfontconfig1 (>= 2.4.0) but it is not installable
Depends: libice6 (>= 1:1.0.0) but it is not installable
Depends: libsdl1.2debian (>= 1.2.10-1) but it is not installable
Depends: libsm6 but it is not installable
Depends: libxcursor1 (> 1.1.2) but it is not installable
Depends: libxext6 but it is not installable
Depends: libxfixes3 (>= 1:4.0.1) but it is not installable
Depends: libxi6 but it is not installable
Depends: libxinerama1 but it is not installable
Depends: libxmu6 but it is not installable
Depends: libxrandr2 but it is not installable
Depends: libxrender1 but it is not installable
Depends: libxt6 but it is not installable
Depends: python2.4 (>= 2.3.90) but it is not installable
E: Broken packages
Can anyone help?
