chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Aug 13, 2013Apprentice
You need to follow mattyshacks' instructions. I don't think you can get this to work just using apt-get. You need to build virtualbox yourself as he described on page 27 of this topic.
steve
steve
