chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Sep 30, 2013Apprentice
Been weeks so you probably already got past this, but what is quite full? The root partition or your c partition? OS reinstall should not affect your data on c, but I'm not certain on the shares. Since os reinstall is used to fix configuration problems I'm not sure what it does with the current share configuration. My Pro 6 root partition is only 33%. You might want to try to ferret out with du where the space is being consumed so it doesn't happen again.
steve
steve
