chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Sep 30, 2013Guru - Experienced User
OS reinstall resets the network configuration to use DHCP, and the admin password to the factory default value ("netgear1" on v1s, ultras and pros, "password" on v2s and OS6).
It does not change the share configuration.
