chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Oct 24, 2013Luminary
Can't run 64-bit VMs on RN516 system, the BIOS has Intel Virtualization Technology disabled. If you try to manually enable it, the system bricks itself.
