chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Nov 29, 2013Apprentice
Virtualbox should really be rebuilt if you change the kernel. I checked just now and the 4.2.25 source zip has not been posted (the line downloads a zero byte zip) so we can't rebuild it yet. When I went from 4.2.23 to 4.2.24 it still ran without rebuilding but there was a bad performance problem.
steve
steve
