chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sander11
Mar 06, 2014Aspirant
Thanks for updating. I couldn't get a straight answer if 4.3 was really the best version so I went up to 4.2.22 which has worked out well. I did get the Q6600 and 8GB of RAM and I am able to pretty easily run 3 medium sized vms. The Q6600 runs a little hotter than I expected but I don't think the virtualbox adds too much, unless the vms start using a lot of cpu of course.
I'm still working out my nagios metrics which was built using eznag and can track data with pnp4nagios so I should be able to figure out in time if 4.2 or 4.3 is better if I really get ambitious.
I clipped and saved one of mattyshack's last updates (vbox 4.3.2/readynas 4.2.24), but I thought he'd posted a bunch of version and the general process was mostly the same. He really helped us all out with those notes.
