chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
MJH77
Jan 24, 2015Aspirant
Hi All,
I have followed the instructions as per post http://www.readynas.com/forum/viewtopic.php?f=35&t=26468&start=390#p388110 to install on my ultra 4 plus some time ago without much success and gave up. I am trying to upgrade my readnas to RAIDiator 4.2.27 though is failing after the reboot with unable to properly extract and is failing back to RAIDiator 4.2.25. I saw a post to remove the symbolic links for apache and apache2 though am unsure how to do this. Is there a way to undo the steps of trying to install virtual box so I can complete the upgrade to 4.2.27.
Thanks,
Michael
Thanks,
Michael
