chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
dsm1212
Jan 24, 2015Apprentice
Installing virtualbox with the instructions was hazardous. I ran this for quite a while, but changes in the distros that netgear and debian posted made it problematic. If you followed the instructions to the letter you probably ended up with a c runtime update that is difficult to undo. If the 4plus is capable of running os6, I highly recommend backing up your data, updating to os6 and reloading. I found I no longer needed vbox because the newer os (debian 7) could run everything I wanted. Sorry, not what you wanted to hear.
