LaszloFolgerts
Aug 15, 2015Aspirant
SABnzbd for RN102
Hi, I've been using SABnzbd on my RN102 for some time now, without much problems to speak of. Recently, I had a pretty big download queue, which it wouldn't finish; it stopped at around 80%. ...
- Aug 16, 2015
Ok, I got it solved!
I'm not sure if it was part of the problem, but I was also having some problems copying some files to my NAS. I deleted a bunch of files but the NAS didn't show any extra space after that. After some looking around I found someone else had a similar problem and it had to do with the snapshots. I deleted all the snapshots of my movies and music shares, because those are where I made the most changes to in the past few weeks (lots of copying and deleting) and it freed up a couple hundred gigs. :)
After that, i thought "what the heck", what if I try installing python again? It installed successfully. I thought well, if that works, how will SABnzbd do? So I installed the .deb file I downloaded from here: http://apps.readynas.com/pages/?page_id=9 and it installed successfully, with all its settings unchanged. :)
very happy! :) :)
