screaminlean
Mar 15, 2015Aspirant
SDK - Setup C/C++ compile environment (amd64)
Hi I am trying to install the build environment on a virtualbox machine running lubuntu-14.10-alternate-amd64 and this part is failing I have installed the key archive but it fails to get the r...
screaminlean
Mar 20, 2015Aspirant
Hi WhoCares
No i have a full config.xml the addon installs and the full directory structure is in .apps and i can manually navigate to the app and it works! All that does not work (Show up) is the Web GUI image / description / launch etc.
