screaminlean
Mar 15, 2015Aspirant
SDK - Setup C/C++ compile environment (amd64)
Hi I am trying to install the build environment on a virtualbox machine running lubuntu-14.10-alternate-amd64 and this part is failing I have installed the key archive but it fails to get the r...
WhoCares_
Mar 20, 2015Mentor
Well, the config.xml is quite picky (or, to be more precise, the code that evaluates it) so chances are your config.xml still is the problem. My advice would be to copy one from another, working add-on and see whether that works. If it does, modify step by step until you either find a bug or have a version that works for you.
-Stefan
-Stefan
