charliejohn
Apr 04, 2023Aspirant
Set up LAG from readynas 3138 to netgear GC752X
This should be simple but its not working out like it should. I want to increase bandwidth between a Dell R530 to the readynas 3138. I have large files that need to be backed up from the R530 to th...
- Apr 04, 2023
Bonding is more effective when dealing with lots of simultaneous flows going to different devices.
LACP in particular is intentionally designed so that each outbound flow can be carried by one of the links in the LAG. The layer 2+3 setting just maps the flow to a particular NIC in the NAS, so that the entire outbound flow (NAS->Switch) is sent on that NIC.
The switch has its own algorithm for doing this mapping in the reverse (Switch->NAS) direction. This mapping often isn't configurable in Netgear switches, and doesn't need to be matched to the NAS setting.
Generally static LAGs work the same way - each flow is mapped to a single NIC in the outbound direction. Round Robin in the NAS is the one exception. That only works one-way since the switch doesn't have a comparable setting.
I don't think there is much you can do here to speed up a single flow between one source and one destination.
Apr 04, 2023Guru - Experienced User
- SandsharkApr 04, 2023Sensei
It is a shame Netgear didn't equip the 1U NAS with a PCI slot. The 2U ones do (at least I think all do, I've never seen a 3312 or 4312) and any Intel X520/X530/X540 10GB ethernet card is just plug-and-play with ReadyNAS OS. Ones based on other chips may be as well, but I know those are.
