Newsat11
Aug 28, 2015Luminary
Setting phpMyAdmin
After installing the application the setup screen states I need a config folder. The installation directions are not clear to me. It says I have to create the config folder in the root directory. I am not sure if the readynas automatically creates this folder or if I sill need to download it from phpmyadmin.net.
- gpaoloLuminary
Hello, I have the same problem.
I'm trying to set up Drupal but before I have to install MySQL ---and before I have to install phpMyAdmin.
The setup want fine, but when I open it I also get this message saying that I have to create a "config" directory.
I'm checking on SSH if I find any obvious place where to create it but no luck until now.
Could someone please give me some instructions?
I'm using a RN314 with OS6. Thanks!
- Newsat11Luminary
Sorry, I just saw this...The config directory is installed when you install PHP. Have you fixed your problem yet? Before installing any of the listed add-ons you have to install PHP. You should start by uninstalling everything and starting with PHP.
- gpaoloLuminary
Hi, no problem ;)
Thank you for the instructions, I managed to have it running after a few days of trials and errors (mostly errors, actually).
The problem is that now I don't really remember how I fixed the issue, but it is possible that I ended up uninstalling and reinstalling everything in the correct order.
