Ashu
May 11, 2020Aspirant
Showing .tmp files in ReandyNAS 424
Hello, I have upgraded version 6.10.3 and after that there are files generating with extension *.tmp I am attaching screenshot as well. Please help. Thanks Ashu
Ashu
May 12, 2020Aspirant
StephenB wrote:Are you seeing them in a share?
How large are they?
Are you seeing more of them over time?
Yes on Shared folders
not sure about size I will ask user.
Yes
Ashu
May 19, 2020Aspirant
How large are they?
Yes
Sizes are randomly not fix. 159 kb 132 kb 25 kb etc,
- StephenBMay 19, 2020Guru - Experienced User
FWIW, I think they are coming from a user PC, and not the NAS itself.
One reason is that I'm not seeing any other reports of this here, and also am not seeing these files on my own ReadyNAS.
- AshuMay 19, 2020Aspirant
Ok We are using Autodesk files from NAS device would it create Temp files?
StephenB wrote:FWIW, I think they are coming from a user PC, and not the NAS itself.
Ashu wrote:
Ok We are using Autodesk files from NAS device would it create Temp files?That's not an application I use, but a quick googling says that it does.
I think there is supposed to be a way to configure the temporary folder where those files are put. Ideally they wouldn't be on the NAS, but on a temp folder on the PC.
