MoonSire
Oct 21, 2013Aspirant
SMB Plus
I just noticed the new "SMB Plus" package in the "Available apps" section on my RN312. It sounds very interesting, very nice work bringing extra options to the people! :) I am just having problems ...
MoonSire
Oct 22, 2013Aspirant
mdgm wrote: What about if you try 6.1.4-RC2?
http://www.readynas.com/forum/viewtopic.php?f=154&t=72282
Or perhaps download it from http://apps.readynas.com/pages/?page_id=9 and manually install it.
The manual install worked nicely, thank you!
(There wasn't much to tinker with once the package was installed though ;) )
- Grenouille25Aug 14, 2015Aspirant
Hello,
I know your post is pretty old but I'm wondering if the SMB Plus changed anything, good or bad.
Can you tell me please?
- StephenBAug 14, 2015Guru - Experienced User
Grenouille25 wrote:
Hello,
Some people need advanced settings for SMB, SMB Plus provides them. If SMB/CIFS shares are working out well for you, there is no real benefit. No harm either though.
- RootaxAug 14, 2015Luminary
Hello,
Do you know if the "pre-allocate" option is really working on a btrfs system ?
Thx :)
- Apr 19, 2022Retired_Member
