Scouser
Dec 02, 2011Aspirant
So I installed the Java addon. But where is it?
Title says it all.
WhoCares_
Dec 02, 2011Mentor
Most likely not on your hard disk and not on the ReadyNAS otherwise you wouldn't be asking ;)
Looking at what the add-on actually does you may try to run this command from your SSH shell and see what happens
This may at least give a clue as to what happened during the installation of the add-on.
-Stefan
apt-get -y install sun-java5-jre
-Stefan
