Scouser
Dec 02, 2011Aspirant
So I installed the Java addon. But where is it?
Title says it all.
WhoCares_
Dec 14, 2011Mentor
The thing is that you probably can't use the ffmpeg as supplied by Netgear because this one has been stripped down a lot. You may be fine by manually configuring the sources as you did but rather than doing this I'd advise to use the Debian build tools like 'dpkg-buildpackage' or 'rebuild' to build the stuff. You should be able to find newer releases of ffmpeg in the Debian repos for Lenny/Squeeze/Sid. Actually I already built one myself for the KMotion project so I know it's doable but it's going to be tough work ;)
-Stefan
-Stefan
