drfrogsplat's avatar
Dec 04, 2016
Softether VPN + ReadyNAS — a better solution for full access to network AND the NAS itself
I tried to set up the Softether VPN and struggled a bit, like many others on here, with not being able to access the ReadyNAS directly when connected.   First I set it up with the bridge to eth0 as...
  • Sandshark's avatar
    Sandshark
    Dec 05, 2016
    FYI, here is the reference:
    While it is possible to designate the physically communicating network adapter used by the VPN Server or VPN Bridge for VPN communication as the physical network adapter to locally bridge to the physical LAN, the following problems may arise.
    • The VPN Server or the VPN Bridge have to separate the frames used for VPN communication such as for cascade connection with another VPN Server, and the frames subject to local bridging, thereby consuming CPU time and slowing communication speed.
    • The Ethernet frames inserted into the physical network adapter have to be copied by both the frame buffer to the TCP/IP protocol stack in the OS and the frame buffer required when inserting for local bridging, thereby placing a burden on CPU time and memory and slowing communication speed.
    Accordingly, when local bridging with a physical LAN, a physically new LAN should be installed on the computer running the VPN Server or VPN Bridge and used exclusively for local bridging if possible.
    [Some stuff removed]
    No Protocol Stack is Used for the Local Bridge Network Adapter
    Where there is a network adapter prepared on the computer for use exclusively in local bridging, it is recommended that the TCP/IP protocol and other protocol stacks be disabled on that network adapter to enhance performance. The role of the local bridge network adapter is to release Ethernet frames between the Virtual Hub and the physical LAN, entirely without the need for intervention from the protocol stack of the OS running the Virtual Hub.
    Obtained from here: Softether VPN Server Manual
ProSupport for Business
