adb1
Jun 11, 2011Aspirant
Sort order for album photos
Having imported a folder, I can't work out the sort order for the photos, it seems completely random. I have photos taken a couple of minutes apart that are rows away from each other. I would have t...
yoh-dah
Jun 17, 2011Guide
adb wrote:
yoh-dah wrote: It's sorting based on upload order. You can typically pre-sort during the upload process (sort by date, filename, etc). Usually, your camera will save the photos in ascending order, so sorting by filename usually will match the Exif timestamp.
This doesn't seem right. I simply pointed the import to a folder tree which contained photos in multiple directories. On directory contained the following few photos from 201 photos in total
23/06/2002 11:49 PM 72,200 PICT0001.JPG
30/06/2002 12:37 AM 75,767 PICT0002.JPG
30/06/2002 12:37 AM 75,037 PICT0003.JPG
03/07/2002 02:44 PM 165,582 PICT0004.JPG
07/07/2002 12:44 AM 137,416 PICT0007.JPG
07/07/2002 12:45 AM 166,301 PICT0008.JPG
23/07/2002 08:48 PM 135,257 PICT0223.JPG
23/07/2002 08:48 PM 137,939 PICT0224.JPG
The Exif dates match the file dates, yet these are completely random in the album view.
The album is useless like this as everything is totally out of order. How can this be fixed?
Cheers
Antony
Can you do a quick check on a test album and try several photos? Make sure the upload window has files sorted by filename.
