adb1
Jun 11, 2011Aspirant
Sort order for album photos
Having imported a folder, I can't work out the sort order for the photos, it seems completely random. I have photos taken a couple of minutes apart that are rows away from each other. I would have t...
adb1
Jun 19, 2011Aspirant
yoh-dah wrote: Can you do a quick check on a test album and try several photos? Make sure the upload window has files sorted by filename.
Not sure what you mean by the upload window sorted by filename...
I am using the FrontView "Manage ReadyNas Photos II" Add on button and in the Photographer Menu there is the option headed
You can import photos from folders on this ReadyNAS. When "Single Album Mode" option is checked, then selected folder becomes an album. If the option is not checked, then sub folder under the selected folders becomes multiple albums.
I then select a share, and Folder to import from, which opens up the folder view of my selected share. Choose a folder and go - there's nothing to chose any sort order
