adb1
Jun 11, 2011Aspirant
Sort order for album photos
Having imported a folder, I can't work out the sort order for the photos, it seems completely random. I have photos taken a couple of minutes apart that are rows away from each other. I would have t...
adb1
Jul 20, 2011Aspirant
yoh-dah wrote: We'll have an update shortly that will allow you to sort by capture time, upload time, or custom time.
Just updated to version 1.0.2 this morning and confirm there is a sort option to sort by capture time or upload time, which does reorder my test sample according to the exif time - Great!
However, the concept of 'Upload time' is not clear, particularly when using the "importing existing photos" option as it's not clear what order is used to upload photos from an existing share. It _looks_ like the import is uploading them in file time order, not file name order, but I can't be sure.
I would really like a preference that allows the default sort order to be set to exif time. Of course I'd also like to be able to rearrange photo order once they are in the DB, but I guess that will take a bit more work.
