imagiro1
Dec 16, 2013Tutor
SSH connection closed
I've enabled SSH. But every time I log in, the connection is closed. What gives?
vandermerwe
Nov 30, 2014Master
ssh [email protected]
Obviously put in the IP address of your 104
Then your password is the same as the GUI login password
Are you aware of the support implications of using ssh?
Have you upgraded to 6.2.0?
