zfil
Jul 14, 2008Aspirant
Subversion : some progress
Hello I've managed to build a working subversion server : wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz First untar ...
ianadavies
Aug 27, 2008Aspirant
Yeah, I had this problem you have to install dev-libc or somthing , if you go to the how to's on the readynas home page and follow the instructions for setting up a development environment first you will be ok
Also I did not change the dev/urandom and it works fine for me it's not slow at all, I could not get it to work with https though once built i use ssh+svn instead. Let me know if it works with https for you
