zfil
Jul 14, 2008Aspirant
Subversion : some progress
Hello I've managed to build a working subversion server : wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz wget http://subversion.tigris.org/downloads/ ... 5.0.tar.gz First untar ...
stevepiercy
Dec 08, 2008Aspirant
Thank you! That was it.
So this step above:
should be:
Now the creation of the repository is fine.
But now I have problems with authenticating. I edited the two files as suggested, but perhaps I did not enter the proper information. Here they are:
For svnserve.conf, I simply uncommented all the options. I had no reasoning behind do so, so if you can advise something more intelligent, I'll go with it. Snipped (...) for brevity.
Actual user and pass obscured:
Thank you for any further help for this newbie.
So this step above:
mkdir -p /c/home/svn/repository
chown svn:svn /c/home/svn
should be:
chown -R svn:svn /c/home/svn
svn@nas-01-B5-6B:~/repository/conf$ cat svnserve.conf
[general]
anon-access = read
auth-access = write
password-db = passwd
authz-db = authz
realm = My First Repository
[sasl]
use-sasl = true
min-encryption = 0
max-encryption = 256
svn@nas-01-B5-6B:~/repository/conf$ cat passwd
### This file is an example password file for svnserve.
### Its format is similar to that of svnserve.conf. As shown in the
### example below it contains one section labelled [users].
### The name and password for each user follow, one account per line.
[users]
# harry = harryssecret
# sally = sallyssecret
myuser = mypassword
